Lane keep assist (lane centring) not good
  • sorry for english, but i do not speak german.
    I have a new initiale paris with traffic jam companion, full option. The lane keep assist (for centring the car in the between the road) is working not really good. On highways it works ok, good (i do find that a lot of small steering corrections are done). However on other roads, 80km speed, with verry good vissible road markings, most of the time the systems does not recognize the road marking at all. Not for centring, but also not when crossing the markings. Just nothing.
    In the display of the car the road markings stay gray, when the system detects the road markings the become green (or white). However on most cases the stay gray even when i believe the system should work in the good conditions, like good markings, weather clean window and speed above 70.
    Has anyone also experience this problem, that the lane centering only works on the highway?
  • it should work okay over the speed from 70 km/h.......try to clean your window shield outside, especially around the camera.
    But you are right, the lane keep assist works very nervous.......go in the system too car assist and try other settings
    Hopefully you have no dirt between window and camera inside.........than you have too visit your dealership
    Good luck......
    Arto
    Gruß aus Berlin :sm:
    Captur II, TCe 155 PS, DSG, Edition One :m0023: alle Assistenten, 18 Zoll Felgen :ah:
    Easy Link Software Version 283C34777R, Kartenmaterial 03.2019, Ersatzrad mit Notbereifung und sonst noch allen Scheiß was kein Mensch braucht :m0032:
  • Ich finde dass es normales Verhalten ist. Wenn die Fahrbahnmakierung schlecht sind kann das System diese auch nicht erkennen.
    Freundliche Grüße
    Ebbe2000
    Renault Captur 2 Intens, in Iron Blau und Dach in Black Pearl. Mit Easy Link 9,3 Zoll, Bose Sound und Haifischantenne. 10 Zoll Instrumententafel, Elektronische Parkbremse mit Auto-hold Funktion, Multi-Sense mit Ambientebeleuchtung, Style-Paket, City-Komfort-Paket, Innenlook-Paket in Blau, Rahmenloser Innenspiegel, Sitzheizung, Toter Winkel Warner, Verkehrszeichenerkennung, Notrad und Wagenheber. Easy-Link Version: 283C38305R. :)
  • ich persönlich finden es zu nervös........man muss sich schon anstrengen immer genau mittig im Fahrstreifen zu bleiben. Vor allem in langgezogenen Kurven nervt mich das. Ich schalte es dann aus......weil mir die Unwucht im Lenkrad auf die Nerven geht, das war bei meinem Tiguan besser gelöst.
    Aber es geht bei jedem Neustart von vorne los wie Start/ Stop.......( wie in jedem anderem Auto auch , leider!)
    Nun man kann es halt nicht jedem recht machen........
  • Hallo Arto,
    Da gebe ich Dir recht. Ich finde auch, dass das System oft zu früh einschreitet. Aber wie schon gesagt wenn die Makierungen schlecht sind kann das System halt nicht arbeiten.
    Freundliche Grüße
    Ebbe2000
    mich bin Espace Phase 2 gefahren, da funktioniert das perfekt. Bei Clio und Captur scheint Renault preiswertere Technik eingebaut zu haben. Bei diesen beiden ist mir der Zickzack-Kurs zwischen den Begrenzungslinien aufgefallen. Auch folgen diese beiden Modellreihen nicht sauber das vorfahrende Fahrzeug.
    Captur Initiale Paris TCe 155 EDC PF Euro 6d-temp
  • Ich dachte bisher das die Einstellungen nur den Spurhaltewarner beeinflusst und nicht den Assistenten...
    Dann muß ich das nochmal testen.
    Freundliche Grüße
    Ebbe2000
  • Arto
    Das ist beim Captur, beim Spurhaltewarner/Spurhalteassistent, definitiv nicht so. Die getroffene Einstellung wird beim abschalten des Motors gespeichert. Ich persönlich mag Spurhaltewarner und Spurhalteassistent generell nicht. Aber zum Glück, einmal alles mit der Klaviertaste abgestellt, kommt es nie wieder, außer man schaltet es selber wieder ein.
    Ganz anders wie z.B. bei den Autos des VAG Konzerns, egal ob VW,Seat oder Skoda, bei jedem Neustart ist der Assistent wieder aktiv. Ich empfinde das als Bevormundung!! Und dazu muss man dort den Assistenten auch noch irgendwo im Menü abschalten, extra Schalter dort: Fehlanzeige.
    Captur Intens TCe 155 EDC GPF; DeZir-rot/black-pearl-schwarz; Infotainment-Paket; Safety-Paket; Easy-Parking-Paket; Winterpaket; freischwebende Mittelkonsole; Ambientebeleuchtung; Sitzheizung; Beifahrersitz höhenverstellbar; rahmenloser Innenspiegel; Ganzjahresreifen 17 Zoll auf Bahamas Silber glänzend; abnehmbare Anhängerkupplung; Renault Plus Garantie 60 Monate/80.000 Kilometer; EZ: 10/2020
    Softwareversion: 283C39164R
  • gemini1706 du hast vollkommen recht.......ich hab ihn auch schon mehrfach abgeschaltet......geht
  • Arto
    Ich habe ihn einmal abgeschaltet, das war noch beim :) ,als ich ihn abgeholt habe :thumbsup:;)
  • Ich habe es verwechselt mit der Schildererkennung........hier in Berlin unbrauchbar! Autobahn unbegrenzt und das Ding zeigt dir 60 Km/H an.......
    Das schaltet sich aber immer bei jedem Motorstart wieder automatisch ein.....:m0016:
